Be aware that Gopher PSU does not limit current at the set limit exactly. For example, if you set 1.4A current limit, it can limit at 1.3 or 1.5A.
However, Gopher PSU shows actual current pretty accurately. Check current with DMM if in doubt.
It is bad practise to "trust" set current limit for precision on cheaper supplies. Always look at actual live current reading.
