Geez, either you're very lucky, or I'm very dumb. I just recently paid a lot more than that for exactly the same thing. I use it to crimp BNC and SMA cables.
I think you're thinking about this backwards -- as you work on projects, you can decide whether you want to build certain cables, and then figure out which PA8000 dies would suit that requirement and buy it there and then. It seems a bit odd to me to just buy a bunch of dies without knowing what they're for?
I guess I was really bad at explaining myself.
Mainly, I am looking at the connectors that I mentioned before.
For the insulated connectors like the following:
It seems like there are multiple crimping dies for use with these kinds of terminals. I will likely need to figure out which one is the best for this use.
My biggest question is that I prefer to crimp the following kind of header connectors and was looking to see if there are any dies which will work with them. These are the arduino style header connectors, nothing special or fancy.
https://www.pololu.com/product/1930I can change the kind of connector to a degree if there is one that works better with the 8000. It almost seems like despite reguarly being recommended the 8000 series crimper is really intended for coaxial type applications and not smaller stuff.
