Weel I've got as far as considering the dongles, unfortunately that's as far as I've got so far. It would certainly be a useful addition as my highest frequency source at the moment is 180MHz. Edit: my frequencies of interest iseem to be lowering with age... tracking my hearing, both tending towards DC.
The resistor sockets are culled from a turned pin IC socket (soldered at the body). Removal is a pliers job,
That little bit of PTFE sleeve makes all the difference to rigidity as it supports the base of the resistor, not just the leg.
For clarity, I'm not the author of the EDN article; I merely linked to it.
Ah yes, I realised that when I actually took the time to re-read the thread (which I notice you also had several posts in too). I had only pulled it up briefly to retrieve my probe photo.
