Author Topic: Ground issue with FTDI MM232R or my computers USB ports?  (Read 1170 times)
Offline kodapa85Topic starter
« on: May 31, 2014, 05:04:36 pm »
Hi everyone!
Recently started playing around with PICs and Atmel chips.
My question is this. Is it possible that my MM232R has a fault, shorting the VCC30 and GND outputs from the FT232RQ or some other fault to raise the GND pin to 3.3V. Or am I simple doing something wrong?
To program a ATMEGA328P-PU I bought a MM232R, wired it up for 5V.
  • Jumper connecting pin 14 and 15
  • Connected both pins 2 and 3 via my breadboard for the positive rail
  • Pin 13 is supposed to be GND and thus connected it to the negative rail
To my surprise the ATMEGA328P didn't seem to do anything. Upon checking the voltage, I found the ATMEGA was only receiving 1.7V. This was because the GND pin was reading 3.3V compared to pin 1, which is connected to the shield.
Needless to say I was able to once I connected the negative rail to shield the ATMEGA works fine and I was able to program it, at last.
Suppose you will want to know the answer to two questions in return :-
  • Why didn't I just use a TLL-232R-PCB?
    • Photos made it look like there were only 3 terminals, also requires soldering
    • The MM232R was cheaper (£11.94 vs £14.34) and is more flexible (5V, 3.3V, 2.8V and 1.8V)
  • Why haven't I used a voltmeter to test for a short?
    • Good question, just haven't yet. I'm not the most dexterous person I wouldn't want to short it out. Now that it isn't powered up I certainly could test it.
