Ok, so... since I just have on the first stage the hi-pass (70Hz) and low-pass (6kHz) I think there's no need to have another on the second stage, right? I removed the low-pass on the second stage.
If I understood well RV1 can cause problems when it goes down to gnd, that's why C1, but also need R3 to avoid shorting, right?
Is there a simple solution to this?
Thanks for your patience.
