Sorry Hero999, I don't understand why to use the first amp as a buffer. Does it add more stability to sound? reduse noise? as far as I know it should change the impedance from high to low. Is it an important step to do befor amplify the signal?
thanks
In my opinion, the input buffer is a wrong choice. It degrades the signal to noise ratio, because it adds its own noise without amplifying the signal. Additionally, it drives a load that is of the same order of magnitude as is its input. So, there seems to be no reason to use it.
Also, high amplification, in one stage only, decreases the available bandwidth of the amplifier...
As there are two amplifiers, it is better to share the amplification work between them, as I have already shown.
By the way, what are the specifications of the pickup? Is there a datasheet? My memory does not help me to remember many things, from a project years ago!
Also what is expected from this amplifier?
The reason for the buffer was to increase the input impedance from 100k to 1M. It will make a negligible contribution to the noise of the amplifier, because it's configured for unity gain. Splitting the gain between two amplifiers, will not make any difference to the noise. For low noise, the amplifiers should be connected in parallel but I doubt noise is much of a concern. The thermal voltage noise, in a pick up with a DC resistance of 15k, at room temperature will be 15.6nV/Hz
0.5, which will be added to some thermal acoustic noise, in the air and strings, as all matter above zero temperature vibrates randomly. There will be more noise in the volume control (maximum when set to 50%) which could reduced in value, if it's a concern.
I agree about spreading the gain across both amplifiers, to increase the bandwidth, although this would require more components. I don't know what the highest frequency of interest is for a guitar amplifier. I don't think it's 20kHz. The TL072 has a gain of around 300 at 10kHz, so a gain of 100 is doable, although more negative feedback is good, so reducing the gain and splitting it may help.
