He has posted this exact same ? to at least two other places.
He has posted this exact same ? to at least two other places.http://www.edaboard.com/thread313193.html
"I NEED FULL DESIGHN OF 2KW INVERTER BOM SCHEMATIC AND PCB ARTWORK" or something along those lines.About 6 years ago every forum you went to would have the same ? haven't seen it in a while. Maybe the guy finally got his wish and killed himself trying to build it.
I won't answer the questions for you, but I will suggest a path to the answer. For the second one, remove the caps for the DC analysis (because caps block DC) and perform the thevenin equivalent on the amplifier.
Mods, is there any chance from the OP's IP address pointing to somewhere close to India or nearby region ? ... calling out Stonent ...
