Hello, I'm trying to read a analog gyroscope using a canbus io-module. The gyro ST LPY410AL outputs a 1.5 +- 1V voltage for the angular rate and a 1.5v reference voltage. The IO module has a 0-10v 10bit adc and provides a 10v reference voltage.
I have designed a amplifier circuit that will take the gyro output and convert it to a 0-10v signal.
e.g. Vout = 0.5*10v_ref + (V_in-gyro_ref) * 5
I'm a programmer by trade so the digital side of things is no problem, but this is my first opamp design.
What I would like to know is:
Is my design sound?
What opamp would you recommend?
The bandwidth is very low, the gyro is measuring the turnrate of a heavy vehicle, so its tens of herts only. The iomodule samples at 40hz.
I have attached a shematic of the circuit and a spice diagram that I used for simulation
Any help appreciated.
