Hey there!
I have an ole
Sharkoon SATA QUICKPORT DUO II which is in perfect working order, but its limits are USB 2.0 and SATA I / 1.5 Gbps.
Now i want to hack it, like this
…the idea is to bypass (cut traces) the slow IC and directly connect the SATA connectors to the eSATA sockets.
Here are some money shots of its nice Rubycon caps
My plan A is to implement this bypass as a "Turbo" switch which energizes some relays that directly connect the storage device through to the eSATA port and let the computer main board negotiate transfer rates. Well, those negotiations will hopefully result in SATA III / 6 Gbps.
I'm a little worried about the signal integrity, because I’ve found some craycray expensive
high frequency relays (
those) on Mouser. Do i really need those? The English Wikipedia article on
SATA doesn't state it, the German one
does; apparently the frequency of the SATA bus correlates with transfer rates, 1.5 Gbps = 1.5 GHz.
How about a trial and error approach? Just use cheap relays and see what happens - if the "Turbo" doesn't work, well than just don't switch it on.
Will i fail?
What about solid state relays?
Are there other types of switching mechanisms i haven't thought of?
