Hello all,
I've got a question relating to Halogen / Incandescent bulbs. Do they have a certain internal resistance that needs to be overcome before they turn on? For example, take a Philips H4 car light bulb (60/55W @ 12V). I assume 55W is the low beam power. So it will pull a bit over 4.5A.
When I try to give it 12V @ 100mA, nothing happens. Not even the smallest hint of light. If I give it a lower voltage (say 5V) at whatever current it wants, it turns on. It just seems to not like small current.
How could I conceivably predict the lowest current at which it will turn on without guessing endlessly? I don't have a supply where I can just dial in the current.
