I've recently acquired (November 25 last year, delivered on December 2nd) a Hantek MSO5102D on eBay, and up to this time I'm very happy with it as a nice basic digital scope, but there is always a catch. I haven't been able to make the LAPC116A Logic Analyzer module included to trigger the right way, triggering occurs perfectly with the two analog channels (GoodTrigger.jpg), but if one selects any of the Digital inputs as source for the trigger, slopes are inverted, i.e., if you choose source Dn on Edge, Rising, it will trigger on the falling edge of Dn, and likewise if you choose triggering on Dn Edge, Falling, it will trigger on the rising Edge (BadTrigger.jpg). It's driving me nuts! And all the analog triggers occur correctly on the falling or rising edges as configured. The pictures show the results when attached to the Probe Comp clip on the front of the scope (5V @ 1 kHz square wave).
I told the seller about this problem and they sent me a new LAPC116A because the original one had some intermittent lines on the left edge (D0~D3 and D8~D11) but the new one behaves exactly the same with respect to the triggering, so I'm thinking about some configuration jumper or switch that's inverting the triggering for the LA module. Information on the scope is (using the Utility Button and selecting F1 System Status) as follows:
[model] MSO5102D
[sw version] 3.2.35(131127.0)
[hw version] 1010x55558340
[serial number] T 1G/012 017056
[boot count] 53 (was 0 when I bought it, yes, I've been playing with it
[upgrade count] 0
[lcd.front.ts] 0.0.0
I really like the scope, and the logic analyzer has nice beginner's options such as triggering on 4 bit patterns, sequences and the like, but it would be REALLY hard to always think in negative transitions to be able to use it in the state it behaves now.
Any ideas to get it running correctly are greatly appreciated, thanks in advance for all your help,
Miguel
