In a few words : I build an led cube(I know...original
) 3x3x3
I have 9 common cathode columns of 3 leds, each column is switched by NPN (BC337, 10k on base, load on collector, emitter to ground ) and 3 common anode levels of 9 leds, each level is switched by PNP (BC327, 10k on base, load on collector, emitter to 5v)
the logic is provided by a PIC16F690 and me with PickIt2 MPLAB and ASM...(unexperimented experimenting beginner)
The All is alimented by a 9v wall wart regulated to 5v with an LM7805...
The cube worked all right for 3 weeks ...my program was too heavy, badly implemented but it worked !
So last week I wrote a new program, tried it ...and I was a happy programer...it was way lighter...I added software pwm...made some tests, a few animations...and proud of myself decided to turn it off...but 2 minute later I turned it on(yeah just to watch it once more...so sad) and there it started...
Now when I turn it on, it does strange animations...then a few minutes later it seems to "stabilize" and run my program correctly
If I try to modify the program during this "strange phase", the result is different... but still not coherent
but if I wait for it to stabilize, every modification applies immediately and correctly...
What I did so far :
- checked voltages...seems ok
- checked for bridges or short...none
- replaced the PIc...no change
- added 10k between MCLR an VCC(even if deactivated by software config)...no change
- added 0.1µf between VDD an VSS...guess what...no change
- uploaded my old badly implemented program...still this strange (but slightly different) behaviour
- today on a breadboard I redid the circuit, except I used 2 ULN2803 to drive the 9 columns...and yes...still strange
While writing this, I realized that it must be software...I just don't get why when I reverted to my ancient code, the bug remained...(or appeared??)
hardware or software...maybe neither, maybe just me....
anyway if you have any suggestions...a tired amateur thanks you in advance
