No need to cut the pin, just make sure it's tied to GND and you only need to fill the first half.
If the pin is tied to VCC, you only need to fill the second half.
If the pin is tied to a processor address line, you may need to fill both half with a copy of each other.
Do not leave the pin open or just cut. This isn't good for CMOS IC inputs.
