Dear djnz,
I am thankful for your suggestions which inspired me in finding a solution to my problem with the Doppler sensor HB100 RKI2680.
Isolation of the two power inputs and circuit trace-out helped me a lot leading to a simple NPN-PNP relay switch. STM8S003F mcu pin 11 was figured out after studying the internal circuit configuration with respect to the present case. Pin 11 and 12 are legs to transfer 12C functions without buffer (un-buffered foot) and pull up resistor. Highly sink capability (first hint). So in circuit boards there may be an external resistor [second hint- in the present board 221(220 ohms) is provided at the pin 11, which is designated as an output] to compensate/protect mcu from getting damaged. The internal circuit is like FET a true open drain (third hint). Consolidating these hints and other observations gave a clue that Blue terminals Vcc has to be supplied with +5 V and in order to pull LED, connect LED positive leg to Vcc and negative leg to output pin 1 in four pin connector, which is connected to stm8S003 pin 11 through 220 ohms resistance. Now it works. Once the object is within the sensor range, LED lights up.
In the uploaded photographs arduino UNO R3 with 9 V battery is used as a power supply Vcc +5 V only.
One can also connect a relay to this output pin 1, if the load current is lower than 20 mA.
One more work has to be carried out with respect to other output pin2 at the four pin connector.
Sincere thanks to Mr djnz and electronics community forum please.
