Trying to connect a 50 pin IDC to a 40 pin IDE.
Am I missing something or do some signals not translate directly?
I know databus would go to data, but Im confused about I/O, as well as BSY, MSG, REQ, SEL, RST, ATN, and C/D. also confused about the +/- pins.
Would I/O on the SCSI side go to IORDY, DIOR, or IOCS16?
Hopefully someone is familiar with these differences, I know this forum is full of brilliant minds so I figure this is the best place to ask.
Thank you
and I apologize for my lack of understanding. (in case this is a really stupid question)
(also I think I could get away with using single ended SCSI, instead of the differential pinout provided. but better safe than sorry.)
50 pin
Pin Name Dir Description
01 GND --- Ground
02 GND --- Ground
03 +DB0 <-> +Data Bus 0
04 -DB0 <-> -Data Bus 0
05 +DB1 <-> +Data Bus 1
06 -DB1 <-> -Data Bus 1
07 +DB2 <-> +Data Bus 2
08 -DB2 <-> -Data Bus 2
09 +DB3 <-> +Data Bus 3
10 -DB3 <-> -Data Bus 3
11 +DB4 <-> +Data Bus 4
12 -DB4 <-> -Data Bus 4
13 +DB5 <-> +Data Bus 5
14 -DB5 <-> -Data Bus 5
15 +DB6 <-> +Data Bus 6
16 -DB6 <-> -Data Bus 6
17 +DB7 <-> +Data Bus 7
18 -DB7 <-> -Data Bus 7
19 +DBP <-> +Data Bus Parity (odd Parity)
20 -DBP <-> -Data Bus Parity (odd Parity)
21 DIFFSENS ?
22 GND --- Ground
23 res - Reserved
24 res - Reserved
25 TERMPWR <-> Termination Power
26 TERMPWR <-> Termination Power
27 res - Reserved
28 res - Reserved
29 +ATN <-- +Attention
30 -ATN <-- -Attention
31 GND --- Ground
32 GND --- Ground
33 +BSY <-> +Bus is busy
34 -BSY <-> -Bus is busy
35 +ACK <-- +Acknowledge
36 -ACK <-- -Acknowledge
37 +RST <-> +Reset
38 -RST <-> -Reset
39 +MSG --> +Message
40 -MSG --> -Message
41 +SEL <-> +Select
42 -SEL <-> -Select
43 +C/D --> +Control or Data
44 -C/D --> -Control or Data
45 +REQ --> +Request
46 -REQ --> -Request
47 +I/O --> +In/Out
48 -I/O --> -In/Out
49 GND --- Ground
50 GND --- Ground
40 pin
1 /RESET --> Reset
2 GND --- Ground
3 DD7 <-> Data 7
4 DD8 <-> Data 8
5 DD6 <-> Data 6
6 DD9 <-> Data 9
7 DD5 <-> Data 5
8 DD10 <-> Data 10
9 DD4 <-> Data 4
10 DD11 <-> Data 11
11 DD3 <-> Data 3
12 DD12 <-> Data 12
13 DD2 <-> Data 2
14 DD13 <-> Data 13
15 DD1 <-> Data 1
16 DD14 <-> Data 14
17 DD0 <-> Data 0
18 DD15 <-> Data 15
19 GND --- Ground
20 KEY - Key (Pin missing)
21 DMARQ ? DMA Request
22 GND --- Ground
23 /DIOW --> Write Strobe
24 GND --- Ground
25 /DIOR --> Read Strobe
26 GND --- Ground
27 IORDY <-- I/O Ready
28 SPSYNC:CSEL ? Spindle Sync or Cable Select
29 /DMACK ? DMA Acknowledge
30 GND --- Ground
31 INTRQ <-- Interrupt Request
32 /IOCS16 ? IO ChipSelect 16
33 DA1 --> Address 1
34 PDIAG ? Passed Diagnostics. Used for 80-pin cable detect.
35 DA0 --> Address 0
36 DA2 --> Address 2
37 /IDE_CS0 --> (1F0-1F7)
38 /IDE_CS1 --> (3F6-3F7)
39 /ACTIVE --> Led driver
40 GND --- Ground
thank you again
