http://www.aes.org/About the mould, I personally think that part is a bit overlooked, it's mostly just for comfort.
Btw, you can make these moulds yourself, pretty cheap and easy.
It's even being done for hearing protection plugs/buds.
I also really don't see why you need such a super fancy acoustic threaded room.
The background noise simply needs to be low enough, the numbers are a bit rusty, but out of my head that should be something like 24-40dB(a) or thereabouts.
This can be very easily done in a standard room with a proper headphone.
Also getting 'calibrated' headphones with ±1dB isn't that difficult anymore.
In fact, it would be better not to calibrate the headphone, but use a compensation on the source.
(technically speaking that's not calibrating, but I know most people use it that way)
Bit again, we are nit picking details, those can easily be overcome, it's about the general concept.
I have discussed this with quite some engineers in the field (went to a bunch of lectures about this subject).
Although that was probably 7-8 years back or so, but NONE of them (even people that DO have marketing skills) understand why they need to cost around $800-1500.
The only thing I remember is that the market is kind of a locked environment.
So it's very hard to get in as an outsider.
@cdev
I really love your ideas.
Doesn't even need to be really at home, but portable is also fine.
That way someone can go to their homes or like elderly homes and do it on the spot.
Ones again, there is no rocket science in measuring it.
