Hot air really isn't very useful in the initial soldering stage, despite what uncle_bob says. It's very slow to use hot-air to solder up a board, painfully slow going. I have never known any ceramic cap or resistor I have hand-soldered to fail. Tin one pad of each 2-pad footprint, pickup part with tweezers, re-flow pad with iron, place part using iron tip as a stop, remove iron, solder other end.
Works fine, a couple seconds per part, compared to, faff about placing solder-paste, place the part(s), get hot air gun, wait for gun to heat, direct hot air towards part, wait a painfully long time for part, board, and solder to heat and reflow (watching paint dry is more fun), move to next part... who has time for that. Only when there is no choice (no accessible pads etc) do I break out hot-air for parts of an initial assembly.
For rework, for removing a part and replacing it, hot air is indispensable, but get a proper hot air rework tool with adjustable heat, flow, and different nozzles, they are cheap as chips but worth their weight in gold.
