I am so sorry. I rushed that post, and I forgot a few details.
I am attempting to build an all in one ESP-01 flasher, but that can be used to flash, reset, test, and use the GPIO and UART outputs to test a program, without needing to remove it constatly. So plug it into the usb pourt, flash it, reset, and test a relay for example, all without unpluging.
I already have a second revision, with 7 header pins. They are GPIO0, GPIO2, 3.3V, 5V, GND, TX and RX. Basically the same, just add appropriate headers, and re lay it out. I can post the layout also.
