Author Topic: Help! Why is this MC34063 INV dose not work properly?  (Read 3277 times)
Offline ali6x944Topic starter
  • Country: sa
« on: June 19, 2016, 11:29:31 pm »
Hi everyone,
I made this switching INV with MC34063, and it is not operating properly...
It should output -15v but it is outputting -5v pluse the cap dose not make any oscillations like it should be considering the fact that I changed the dameged chip I made sure of all connections and thay all seem ok...
Photors:
https://drive.google.com/folderview?id=0B5vW-k7HbsL4UkxvYU1hM3QtMTQ
« Last Edit: June 20, 2016, 12:13:32 am by ali6x944 »
  • Country: sa
Re: Help! Why is this MC34063 INV dose not work properly?
« Reply #1 on: June 20, 2016, 12:48:15 am »
List of parts:
3 one ohm resistors
2 one k resistors
1 10k resistor
4.7k resistor smd 1208
100uh inductor
1nf cap
470uf 25v cap
SS34 smd shottky barrier diode
3mm red led
MC34063A SOIC-8
Calculations:
R1=1k
R2=11k
Vin=3v
Vout=-15v
Iout=100mA
Vsat=0.7 -I picked the worst case scenario-
Vf=0.4 -see instantaneous forward current to voltage drop graphf
Fout=32k
Vripple(pk-pk)=0.1mV
ton/toff=6.695652174
(ton+toff)=3.125*10^-5
toff=4.060734463*10^-6
ton=2.718926554*10^-5
Ct=1nf
Ipk(switch)=~1.5
Rsc=~0.3
L(min)=~42uH
Co=470uF -its kinda over kill-
Offline JoeO
  • I admit to being deplorable
« Reply #2 on: June 20, 2016, 01:20:41 am »
Schematic?
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
  • Country: sa
« Reply #3 on: June 20, 2016, 09:49:07 am »
Oh.... I forgot I will post it in a second
  • Country: sa
  • Country: sa
« Reply #5 on: June 20, 2016, 07:00:58 pm »
 Now did u see it the pdf
Offline bktemp
« Reply #6 on: June 20, 2016, 07:48:20 pm »
Connection between pin 7+8 and input capacitor are missing in your circuit.
  • Country: sa
« Reply #7 on: June 20, 2016, 09:52:08 pm »
Input capacitor is not necessary
I fixed it and still not working properly....
High output voltage of -5v instead of -15v and no oscillations on pin 3
Offline JoeO
« Reply #8 on: June 20, 2016, 10:00:49 pm »
There are many differences between your schematic and the schematic from the spec sheet.
  • Country: sa
« Reply #9 on: June 20, 2016, 10:39:55 pm »
Mine is a mirror image so it is flipped...
Don't forget the connection between pin 8,7 and I mistaken
And drawn the feedback resistor connections.
« Last Edit: June 22, 2016, 11:27:58 am by ali6x944 »
  • Country: sa
« Reply #10 on: June 21, 2016, 10:59:48 am »
I'm not quite sure but if the output cap or timing cap is shorted or damegd it will give a similar behavior so I will check...
Offline Ravenghost
  • Country: lt
« Reply #11 on: June 21, 2016, 07:03:24 pm »
Could it be that you connected a load which resistance is too small and it goes into current limit(i believe yours is limited to 0.5-0.7A) and therefore output voltage goes down?
  • Country: sa
« Reply #12 on: June 21, 2016, 11:42:20 pm »
I don't think so, because I designed it for an output current of 100mA and and the led with the resistor I chose would give a current draw of around 3 mA, but I will remove the led and see what will happen
Offline JoeO
« Reply #13 on: June 22, 2016, 01:11:19 am »
Your schematic and the sample schematic are different in many ways.
Your schematic is WRONG!
Offline Skimask
« Reply #14 on: June 22, 2016, 01:25:06 am »
You designed it?
How?
Did you consult the datasheet?
Or just throw random marks on a piece of paper somewhat resembling a schematic, collect more random parts that looked fairly similar to the things on that piece of paper, and start soldering random stuff to other random stuff?
Ya that'll fix everything!!!
Uhh...No...
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
  • Country: sa
« Reply #15 on: June 22, 2016, 11:18:28 am »
I removed the led and nothing happened...
Also I redrawn the schematic to make it clear because I missed some connections on the board, sorry if I  intimidated some of you  by not updating the schematic when I modified the circuit on the board so please forgive me for what happened.
« Last Edit: June 22, 2016, 11:36:13 am by ali6x944 »
  • Country: sa
« Reply #16 on: June 29, 2016, 02:45:20 am »
So what shall I do??
