from the center wire, all 4 others should measure the same resistance, or very close to, he will be connected to supply, the other 4 will be switched low in sequence, should be the same as a 6 wire unipolar,
it is likely that it requires overlapping steps rather than just 1 on at a time, e.g. A, AB, B, BC, C, CD, D, DA.
