Author Topic: Help figuring out which plug do I need for this?  (Read 2869 times)
Offline R-M-ITopic starter
« on: June 09, 2012, 07:10:27 am »
I need to buy some 5-pin JST plugs with wires crimped onto it..
The problem is, there are heaps of different 5pin connectors around and there are no markings on the connector itself(that I can see)..
This is the connector I'm talking about:
It's about 9mm long, 5mm tall..
I'd LOVE it if anyone could link me to a eBay-item or shop that I can buy it from..
Offline ikrel
Re: Help figuring out which plug do I need for this?
« Reply #1 on: June 09, 2012, 07:21:30 am »
Sparkfun might have what you're looking for:
http://www.sparkfun.com/products/10360
« Reply #2 on: June 09, 2012, 07:30:16 am »
I have that exact plug/connector.. And unfortunately it does not fit at all..
Offline ikrel
« Reply #3 on: June 09, 2012, 07:39:48 am »
they sell the whole package you could replace the connector on the board?
« Reply #4 on: June 09, 2012, 07:49:06 am »
I see that.. But I figure it would be a advantage if the connector-pins would actually fit into the board-holes if I were to solder in a new connector.. I don't want to replace the connector on the board... I simply want the plug that fits into the connector on the boards I already have.. I've contacted JST in the US and UK.. Hoping they will be able to help me out..
« Last Edit: June 09, 2012, 07:59:46 am by R-M-I »
Offline Short Circuit
« Reply #5 on: June 09, 2012, 11:02:42 am »
JST ZH perhaps? 1.5mm pitch 5-way is 9mm wide
http://www.jst-mfg.com/product/detail_e.php?series=287
« Reply #6 on: June 09, 2012, 11:38:15 am »
Hmm.. That LOOKS about right :) I'll give it a try :) thank you!
See the pitch is 1.5mm, so I guess it's the right connector :)
EDIT:
Just bought 10 of them on eBay.. I'm sure I can use it for something if it can't be used for the boards I have :)
« Last Edit: June 10, 2012, 10:12:24 am by R-M-I »
