Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
Using Voltage Divider to Make HV Measurements
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Using Voltage Divider to Make HV Measurements (Read 1530 times)
eerocketman
Contributor
Country:
on:
July 26, 2017, 03:43:17 am »
Hi everyone!
I was just wondering if I could use an RC filter at the output of voltage divider to reduce noise in the readings. I have attached the circuit I have in mind.
Thanks,
Ali
Logged
joeqsmith
Super Contributor
Country:
Re: Using Voltage Divider to Make HV Measurements
Reply #1 on:
July 26, 2017, 03:55:50 am »
0805s?
Logged
How electrically robust is your meter??
https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Solver64 Dropbox
https://www.dropbox.com/scl/fo/j7pypmli6knwnrb2e7ejb/h?dl=0&rlkey=2lnag44rmdkx0f0cgk0x0jfri
eerocketman
Contributor
Country:
Reply #2 on:
July 26, 2017, 04:00:30 am »
Probably several 2512s in series, they were part of the symbol I'm using for resistors.
Last Edit: July 26, 2017, 04:02:30 am by eerocketman
Logged
Zero999
Super Contributor
Country:
0999
Reply #3 on:
July 26, 2017, 09:03:41 am »
It's a reasonable idea. Obviously not with 0805 parts. The voltage and power rating of both (especially the upper) resistor needs to be respected.
Here's a link to a site which a handy calculator for selecting resistor values to use in a potential divider.
http://sim.okawa-denshi.jp/en/teikokeisan.htm
There's no need for another resistor to make the RC filter. The output impedance of the potential divider is equal to both resistor value in parallel, so just choose a capacitor to give the required cut-off frequency.
Logged
perieanuo
Frequent Contributor
Country:
Reply #4 on:
July 26, 2017, 12:56:46 pm »
Yes hé can do it with 0805 or even smaller,just put 50-100 in series
Envoyé de mon iPad en utilisant Tapatalk
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
