I'm an experienced electrician working at a car audio installation shop and today my salesman brought something quite interesting to my attention. We have a demo wall with many speakers, subs, amps and radios. Everything is connected via a matrix switch. There are separate switches for the radios, speakers, amps, etc. When, and only when, you have either a sub amp or a 4 channel amp selected, as well as a speaker of course, you can hear FM radio playing quietly (but not that quietly) out the speakers (mostly the rears), even when the selected radio is muted and not on the FM source. So I think the answer is obvious and one of the other radios is playing FM and it's somehow just bleeding into the audio lines. So out of curiosity I turned off every single radio and low and behold, still FM playing through. Now, I'm thoroughly confused. How is it possible that without something to cancel out the carrier wave can actual radio be playing through a speaker? Seems crazy, right? I'm sure I turned every radio off. None of them have antennas plugged in. When I turned off one of the 2 amp channels, it went away a little. Only when I turned them both off did it completely go away. If you turn the volume up on the selected radio it overpowers the FM quickly so it isn't a problem to demo.
What's going on here? I'm beyond clueless.
