The SOIC8 7812 regulator is missing from the order. This 8534 came in its place. every other item checks out.
I already called my supplier, they were also a little puzzled about the this IC when I told them it was 8534. They couldnt figure it out right away.
They just said, "no problem, we are immediately sending you the SOIC8 7812 chips you ordered. You can keep the unknown ICs."
