My multi meter does not have diode mode.. though guess I could probably do the same using a LED and 5 volts? Is that basically what the multimeter is doing? I have to look at getting a better multimeter though, but been spending lot of money latetly on this new hobby.
So I found a MJE13001 datasheet says 1: emiter, 2: colector, 3: base does that sound right?
So emitter goes to ground, collector goes to load, which is connected to positive of a higher voltage/amperage (if desired) source, and base is put to ~5v to turn on and off, correct?
