This is from metal detector pointer: Vibra Probe 580.
The second picture is of the tiny coil, 15mm diametre.
Firstly I want to change the vibrator to a smaller one, pretty easy, I might use a resistor if necessary.
I do want to replace the coil for a ferrite core coil. However that might be a job that requires tuning with a scilloscope.
To turn the coil on it is held upright for 3 seconds. However it auto turns off 1 minute after last detection, a very annoying feature. I really want to be able to increase this timer to 5 minutes. I suppose that would require reprogramming a chip, perhaps only reorganising the circuit board.
I'll map it if anyone wants (I've partially started).
I have a multi meter and LCR meter.
How do I test the N components, or can I identify them by the labels?
Are they Varator diodes?
Can I measure all the tiniest R & C components while off?
Guess I'd use the LCR for the C (capacitors?).
While trying to ID some of the components I came across these pages which I found to be very helpful:
Testing components
http://www.talkingelectronics.com/projects/Testing%20Electronic%20Components/TestingComponents.htmlPCB markings
http://electronics.stackexchange.com/questions/25308/what-do-the-pcb-markings-meanGLOSSARY FOR THE ATTACHED IMAGE.
B - they have 4 pins each
N - are these the same thing, how would I test them/identify them. Small one reads 44 & D3 written on the PCB (some read IP with Q3 written next to them) Varactor Diodes?
T - vibrator
H - 16.0M, U3 written on circuit board, mlc?
Y - PIC16F5 -/ISO (Flash-Based, 8-Bit CMOS
Microcontroller Series) Data sheet was found.
U - [PEUAC] MM74HC 132M Not sure which data sheet this is?
I - EA33 LM 324M (Low Power Quad Operational Amplifier) There are data sheets, but I can't find one ending in only 324M
O - S 1346 P BSP170
A - jumper to connect the coil
