From the label you can realize that is an AC motor 110v. And that it uses a capacitor of 20uF so it is an induction motor. Also called "squirrel cage" type. Its speed depends almost entirely on the line frequency. Rpms are shown for 50 and 60 Hz.
It would have at least 3 wires where you must connect line, neutral and the capacitor.
