Hi all,
These two components are from a NiCd battery pack (9.6V - 8 1.2V cells in series).
I'm pretty sure the red component is an NTC, and I think it is a 6.8k. But I wanted to check with you guys if I read it correctly. At room temperature, it reads around 7.5k - 8k. It might be just old and out of spec. Can it be a higher value? The marking seem to say 6k8k.
As for the square component, is it a cap? Markings 100 , 1826, 9513. Some kind of poly or foil cap?
Thanks
