Hi all,
I picked up a cheap dead satellite box which was broken.
I replaced the 3.3v reg and diode which fixed the boxes no boot issue (first time reworking smd !)
Now I have found the input to the inductors on the tuning board is only 12v and not the 13.2 or so volts it requires.
After probing around the board I found that it traces back to this SOT23-6 part .. but what is it ? I has a input of 12 volts and 12 volts out...
And a transistor is also nearby, thanks for any help
