Author Topic: Help identifying this IC  (Read 4377 times)
Offline giosifTopic starter
« on: July 26, 2015, 09:44:51 am »
Hello,
Can someone please help me identify the IC in the attached picture (i.e. brand, model)?
The logo seems to indicate it's a Motorola, but I could not find any such product with that model number.
Thanks,
George
Offline tautech
Re: Help identifying this IC
« Reply #1 on: July 26, 2015, 10:25:18 am »
The type of equipment it's in might help us.  :-//
Also a Service manual for it may have the part listing and device type.
Avid Rabid Hobbyist
Offline Psi
« Reply #2 on: July 26, 2015, 10:44:44 am »
Its almost certainly a 8050 cpu of some sort.
Says 8050 on it and those did come in 40pin dip packages.
It also looks old enough.
« Reply #3 on: July 26, 2015, 11:26:43 am »
Mask ROM version of the 6800 family, easy to see from the Motorola logo, the mask version number, ZC probably a customer number, the 0002 the mask number so either the second version after the first 10k units did not work or they did a firmware upgrade on the system, and the P indicating a plastic package. Could also be the OTP Eprom version of the 6800 processor, which was often done for low volume customers who would order 1000 at a time.
The 8050 is a date code, week 50 of 1980, reinforced by the support TTL being dated 1979 to 1981.
IC6 and IC7 were probably there for ROM chips used during the development cycle, so the 6800 is a version with 2k of ROM on die, and probably 128 bytes of RAM as well.
Probably a MC6802 or 6808, depending on what is connected.
http://www.andysarcade.de/data/electronics/components/6802_6808.pdf
If no rom chips, it is a MC6801. Most likely candidate for sure if there is no ROM or RAM on the board, it has a whole 2k of ROM ( you can fly to the Moon on 2k) and 128 bits of RAM.
http://www.andysarcade.de/data/electronics/components/6801_6803.pdf
« Last Edit: July 26, 2015, 11:31:06 am by SeanB »
« Reply #4 on: July 26, 2015, 12:04:39 pm »
Thanks everyone for your answers!
The equipment is a bench multimeter (Solartron 7060).
This is on the processor board.
Service manual... eh... if only I could find one (have been searching one for months)...
Amm... I think that's a date code (SeanB has just confirmed it).
I think you are on to something here: a quick check and it seems the pinout matches the one on the MC6802/8.
IC7 is an SRAM and IC8 (not IC6, the number is not that readable in the picture) is an EPROM.
Now, there is also an IC6, but that's not visible in the picture and it is an MC68488 (from what I could gather, that's for the GPIB interface).
Many thanks again,
George
Offline miguelvp
« Reply #5 on: July 26, 2015, 06:07:41 pm »
Maybe this thread helps
https://www.eevblog.com/forum/reviews/solartron-7061-help-and-come-photos/
It has links to service manuals that might be close enough to yours.
« Reply #6 on: July 26, 2015, 06:18:43 pm »
Thanks for the info!
I was aware of that thread already.
However, even if there's only one unit difference in model numbers, the devices are (to me) very different.
Thanks anyway,
George
Offline woodchips
« Reply #7 on: July 26, 2015, 07:46:45 pm »
Manualsplus.com have a 7060 service manual, buy it quick before they close.
« Reply #8 on: July 26, 2015, 08:19:21 pm »
Wow, they actually have the service manual for it!
But, alas, it doesn't come cheap and, being a site in the US, I expect there will also be a shipping cost.
But, at least I know where to go next time I hit the jackpot.  :D
Thanks woodchips!
Regards,
George
« Reply #9 on: August 04, 2016, 05:20:07 pm »
Old topic, but I thought I'd add the information here, for any future owners of faulty Solartron 7060 voltmeters: basically, SeanB was right on the money with the suggestion that this chip might be a Motorola MC6802 - the actual model is MC68A02P.
After such a long time, I was finally able to identify the fault with my 7060 - the CPU MC68A02P has died.
Offline CJay
« Reply #10 on: August 04, 2016, 05:26:55 pm »
Also worth adding as a general note, Motorola parts with a ZC partnumer are usually customer numbered.
Did you find a CPU?
