Author Topic: Help me decide/decypher capacitor types for this schematic  (Read 1759 times)
Offline JoeNTopic starter
  • We Buy Trannies By The Truckload
« on: August 17, 2016, 12:42:57 am »
This is a circuit I would like to try to build.  I have one problem with this thing, I can't tell what capacitor types Jim wants me to use based on his instructions.  He says:  1) Do not use ceramic capacitors anywhere.  2)  Use Mylar or Silver Mica.  3)  0.01uF=Polystyrene Preferred.  These instructions just don't make sense to me because a bunch of the values are way too big for Mylar/Silver Mica and a bunch of the capacitors on the schematic are polarized, this seems to me he is indicating electrolytic, right after saying not to use them.   I guess you have to.  Here are the capacitors on the schematic, what kind do you think they should be?
10000pF - Use polystyrene like Jim said?  Are there more modern choices that would work?  Could polypropylene be used instead?  How about mica?
5pF - mica?
6800pF - mica?
.1uF - since ceramic is out, I guess we must use aluminum electrolytic?
.47uF - since ceramic is out, I guess we must use aluminum electrolytic?
15uF - Aluminum electrolytic?
10uF - Aluminum electrolytic?
47uF - Aluminum electrolytic?
100uF - Aluminum electrolytic?
Schematic:
http://cds.linear.com/docs/en/article/ubm_edn_20110811%2018Bit%20ADCs%20Ad%20Free.pdf
« Last Edit: August 17, 2016, 12:45:26 am by JoeN »
Have You Been Triggered Today?
Offline Len
Re: Help me decide/decypher capacitor types for this schematic
« Reply #1 on: August 17, 2016, 06:56:39 pm »
It doesn't specifically say not to use electrolytics, only ceramics are completely banned. I think it's obvious that the polarized caps (all fairly large values) are meant to be electrolytic.
Mylar (PET) capacitors are easily available in the microfarad range, I don't see a problem with using those for the 0.1, 0.47, 1 uF values.
DIY Eurorack Synth: https://lenp.net/synth/
« Reply #2 on: August 17, 2016, 07:31:56 pm »
5pF can definitely be a NPO ceramic, and for the 6n8, 10n, 100n, 470n and 1uF use either polyester or polypropylene, which will work here.
« Reply #3 on: August 17, 2016, 10:54:02 pm »
Thanks for both replies!
