The neutral voltage is the average of the phase voltages.
I simmed the ADC input clipping using behavioural voltage sources then plotted the power. Due to the fact that you cant reuse a calculated trace in other trace expressions, I also added a BV source for the calculated neutral. See voltages aa, bb, cc and nn in attached sim which are the clipped version of a,b,c, and n.
