Hi, I just bought a raspberry pi and I remembered some years ago I stored a car tactile "tv" (only video input actually) that I got for free but I didn't know how to use, and since I didn't needed it I stored it until now. This lcd would be great for my raspberry pi and a project I want to make to make my sdr radio portable. The tv It has a bunch of cables and a vague "schematic" to tell where they go but for the moment I only figured out which are the two going to the 12v supply.
You can't see it very clear there but it says
Red line to the + terminal of the battery "black line" to the - terminal of the battery. Green line to ground. "Black line"(again?) to a Key simbol with VACC letters on it.
Now the weird thing is that there's no two black cables but because of the section of the cables I figured out what the negative terminal for the battery was. It was a white cable. Connecting the red and white cables to a 12v power supply poweres up the ON button on the tv but pressing it does nothing. I think the key thing has something to do with this.
So I have 2 cables left to know what to do with them. A green cable which according to the schematic is ground and a black cable with the letters VACC on it. I measured across them and it's 4.73V. At first I thought the key thing could be just the contact, like you wire that to your car key contact so it powers up when you insert the key. So maybe connecting the green and black wires together should start it up like it's a switch but I don't wan't to short circuit anything so I don't know what else to do.
What can I do to start this up? I tried to search for online info but it's a chinese tv with no model or number references on it. Any ideas? Thanks
