I think people get poor results with IPA if they let the alcohol just evaporate naturally after brushing. You end up with a PCB sticky all over the place.
You need to scrape/brush off that rosin-dissolved alcohol off the board, AND then follow up with clean alcohol and wipe/pat-dry. The pat-dry and wiping is important too.
