The power supplies that use those classic large and heavy transformers are more sensitive to the input voltage. Those transformers output a voltage that's a percentage of the input voltage ( for example 230v in, 24v out makes it 9.5 : 1 , so if you have 195v at the socket, the transformer may output only 20v and that could hurt the device.
The soldering station... will probably be fine, most of the energy is used by the heating element, and lower voltage just means it will heat up slower.
Your DIY power supply... well, I guess it depends on your design.
Your problem may be related to the mains frequency.. due to the flooding or whatever happens in your country, the power grid may be affected and the mains frequency may move around, won't be a stable 50 Hz. Some classic transformers will make noise when they get such mains frequencies combined with irregular input voltages.
Computers, monitors etc use switching power supplies, which work differently, rectifying ac voltage to dc (up to 400-420v) and then convert it to lower voltages, so they're not so sensitive to mains voltage or frequency.
