I recently got a ds1102e. When i connect it across a powered pnp or npn transistor (Between the base and emitter) I get an extremely weird waveform that is extremely unstable but semi trigger-able and view-able if you use the stop button. After this when i disconnect everything, my oscilloscope gets all wonky and if i cycle the power, it starts up with a blue flash and some noise then the splash screen for rigol. I hope i am not harming my oscilloscope? Can you tell me if it is bad for the scope or my scope is bad, etc.
