I just finally repaired an old Fujitsu Siemens 19 inch Monitor (because it has a very nice image and I wanted to keep it) last week at work and maybe it could help you:
Actually I "repaired" it 3 times
First 2 electrolytic caps on the secondary rail were blown. I changed them and the Monitor worked for 2 weeks. Then nothing worked.
I took it back home and changed the other caps. I hooked it to my private computer as second monitor (for stability test), but it worked only for another day. But next day back at work, the monitor was going on and off and on and off, only showing the start logo for half a second.
What can I say
, took it back home, changed all other electrolytics I hadn't changed and tested almost all components on the main power supply.
All fine. But... during this I red, that it could be the ccfl backlight transformers ( or the controller chip, which went to protection mode).
I desoldered the one of the two transformers out which was suspicious to me... and it worked again
I measured the transformer and...no shortcuts.
Hmmm...there was only one component near the transformer left and this was a blue polypropylene capacitor.
Capacitance was good, but showed no esr value - the other blue PP cap showed both.
I bodged in a new one (actually a bigger old one from my parts bin) in place of this cap and soldered the transformer back in.
And now the Monitor is back to life for a good week without any problems
and I think it will be good.
Be careful with the high ccfl voltages and the big input cap
I would never have suspected the lil cap, so check really everything, all the lower power supply output voltages and components around the ccfl transformers.
I hope this little story helps you and good luck
, Tom
