Hi guys!
I was looking at the attached simple power supply schematic this afternoon, and noted that the power and ground pins of the LM324 are placed before the 7815 regulator.
The circuit is designed to be used with a laptop DC adapter, so I wouldn't have thought a stable DC voltage would be an issue, but I'd have thought that the power pin should be placed after the regulator, if for no other reason than the slightly reduced voltage and chip stress and life length.
Can anyone see a reason I've missed as to why it should be placed before the 7815?
*Edited to ensure the schematic fits without scrolling
