Author Topic: Help with small video switching project.  (Read 1005 times)
Offline BradleyTopic starter
« on: April 07, 2015, 10:13:09 pm »
Hi guys just here for beginner advice. I don't have much electronics experience but have built a few small circuits successfully for my RC plane hobby.
I am trying to build an RSSI comparator for video switching. Please see attached circuit diagram.
The first op-amp buffers and scales the RSSI. The second is the comparator.
I am able to manually switch video signals just fine with the switch. My problem is that the MAX4547 requires a signal much closer to the supply voltage than what the LM358 outputs and is stuck on the low signal channel no matter the output. (peaks ~10V)
Is their an opportunity to add an pull up resistor here or should I start again?
Any help appreciated thanks.
-Brad
