SAT and PSAT are now aligned with Common Core making it a total waste of time in terms of accessing student's academic ability.
Have you ever read the common core standard? It's pretty short. New math isn't even an inherent part of it ... you could satisfy it's requirements, from just a standard point of view, with a class based on 40 year old books with a few supplementals for number line insight AFAICS.
It's the certification process of class room materials which is broken. The level of math proficiency common core demands for college entry level is quite sufficient, so SAT/PSAT being aligned with it means nothing. If the writers of the SAT/PSAT tests are of the same quality as some of the common core textbook writers then there is a problem.
As for New Math, it reminds me a bit of functional programming, clever ... yet completely incompatible with my brain. If all teachers and text book writers had very high level math capabilities I think new math wouldn't be a problem, the problem seems to be that most of them don't really understand it either. Just like functional programming it's simply too clever for most people (at least to adjust too once habits have been formed).
Yes I have seen Common Core standard. I have been paying attention to it before it is even called Common Core.
The "It's the certification process of class room materials which is broken" is a loaded statement. (To that, I mean "tip of the iceberg")
To be more precise, it is ok to have a lowest common denominator
standard. However, when that translates into a lowest common denominator universal
curriculum, than it becomes a problem. It turns "everyone minimum X" to everyone = X. So conceptually, rather than common core
standard being the problem, the common
curriculum is the devil in the details and that is the problem. So in that sense, I agree with you.
Conversely, testing should not have min-X as goal. The value of "above grade level testing" is well establish. That is what enable a distinction between good and very good and very very good.
SAT was not a test of knowledge - rather, it was a test of ability to learn (
Scholastic
Aptitude Test). ACT was the test of knowledge. In theory, SAT should not need to change regardless of changes to the curriculum. Now that SAT is realigned as "how much you have learned from Common Core", what then is the difference between it and ACT?
As to "new math"...
"New math" is not suitable for teaching kids. For someone with good understand of various mathematical theorems, it is easy to understand how this method arrives at the answer. But for kids without a firm understanding all those
foundational knowledge, it is incomprehensible. (Foundational in this case is "Associative Law", "Commutative Law", "Distributive Law", and their likes). And you can't really understand these fundamental rules before you learn what is multiply and what is divide.
Perhaps it is in the same spirit that the first draft of "race to the top" (common core before it was called common core) had kids learning division before addition.
