Hi all, I wouldnt exactly call myself a beginner but this is a bit out of my comfort zone so chances are it's something simple which I am missing / doing wrong.
While repairing an old hi-fi system, initially damaged in a lightning strike, I came across a hex inverter chip (74LS05P) that seemed to have some unusual readings ie: inputs and outputs are not inverted.
I took the chip out of circuit and placed in a breadboard, then connected to a 5V DC supply with +ve to Vcc and -ve to Gnd pins. I then connected each input in turn to +5V and then to 0V, expecting to read the "opposite" voltage at the output, however the output (for all 6 inverters) remained very close to 0V despite what was connected at the input. With the inputs left floating they (inputs) each read somewhere between approximately 1.5V and 2.1V.
That seemed to me to be pretty conclusive that this chip had failed, so I ordered a replacement.
Today the replacement has arrived and so I tested it on the breadboard in the same way as before and found... EXACTLY the same results!
This leads me to think one of two things:
- I damaged the new chip by handling it. I do not have a wrist strap or ESD safe board so it's a possibility although I did earth myself prior to handling, I know that's not ideal but its the best I can do right now.
- I am misunderstanding how these chips operate and the test I devised is actually useless! Somehow this seems more likely as this is the first time I have encountered these and am not too familiar with logic circuits, although have studied the theory (Boolean algebra etc.)
Any thoughts?? Is there an accepted method for testing operation of these chips without anything fancy like a scope? The few examples I have found online don't seem to be accouting for anything I am not.
Any help is much appreciated!
