Author Topic: Hi forum I am having a little problem with my Rigol ds1104Z  (Read 1174 times)
Offline barak198
  • Country: il
« on: December 18, 2015, 10:35:05 am »
I am sampling the  voltage from a signal generator in CH1
 and the voltave  over a resistor (10k)  in CH2
there is nothing else in this circuit
the scope shows the waves as if there is a phase shift !
what is the problem ?
thank you
Offline barak198
  • Country: il
Re: Hi forum I am having a little problem with my Rigol ds1104Z
« Reply #1 on: December 18, 2015, 10:42:03 am »
got it !!
the invert button was on...
Offline Fat
« Reply #2 on: December 18, 2015, 10:46:28 am »
Glad to see I'm not alone. |O
Offline barak198
  • Country: il
« Reply #3 on: December 18, 2015, 10:48:12 am »
I am still learning how to use it :)
Offline dan3460
« Reply #4 on: December 19, 2015, 02:53:12 am »
Once I spent more than one hour trying to find out why my scope would not give me the trace that I was expecting, instead was giving me this noise and I could see the 60Hz background noise. I pushed buttons, check my source, click the "auto set" several times. I was about to give up when.... ta ta ta taaaam  :-\ The probe that I was using to probe the circuit was not connected to the scope, I had grabbed a spare probe!! |O
