You're not going anywhere if you don't know Ohm's Law and to be truly capable of figuring out what is happening, you need to understand Kirchhoff's Current Law.
In particular, you need to understand that the voltage at the - input is exactly the same as at the + input. Op amps work to force that to occur. As a result, the voltage at the - input is exactly zero.
Therefore, every bit of current that comes in through the input resistors flows out through the feedback resistor and there are some interesting mathematical properties that come about because of this. So, this current (per path) is simply the voltage divided by the resistance. All of those currents add and cause a drop across the feedback resistor. Given that you can calculate the drop across the feedback resistor and the - input end is 0V, you can calculate exactly the output voltage of the op amp.
https://www.electronics-tutorials.ws/opamp/opamp_4.htmlw2aew's video on summing op amp circuits:
More basic is his earlier video
I don't know what class you are taking but you need to gather up some background information before you will truly understand what is going on with this circuit.
I am not going to write the KCL equations, the videos will help with that.
