Hi David.
It was added to override diode barrier of the first transistor, and make zero cross pulse, closer
to real cero voltage. Shifting it, a bit to the¨right¨
if I take it out, circuit looks a lil more prone to sporius firing near 180 degrees, but not big deal.
Was reading that a 0 cross detector with OP AMP and histeresys, and PIC micro programmed to reject
out of time 0 crossing, can make it more reliable .May be
Keep watching ...
