Hi I am trying to filter a 7MHZ signal using RLC-LPF. My signal flow are as follows.
I am taking in a 6.78Mhz AC, rectifying it in a full wave rectifier. I then send it to a LPF (around 7Mhz; R = 430, C = 100pF, L = 4.7uH.) My problem is I still have high frequency harmonics around 14Mhz to 140Mhz. I compared the signal with and without the LPF, and difference are very subtle.
Hi
What you have built is a classic frequency doubler. It will have a *lot* of energy at higher frequencies.
R/C filters are rarely seen at HF. Why? because they don't roll off very fast. You don't say how your parts are hooked up, but at 7 MHz:
4.7 uH = 206 j ohms
100 pf = 227 j ohms
R = 430 ohms
Those values don't look a lot like a normal lowpass filter. What is the driving impedance (if not 430 ohms)? What is the load impedance? (if not 430 ohms).
So what are you trying to do?
If you want DC, then set your filter to a much lower frequency. 4.7 mHy and 100 nF might be good bets.
If you want the ~7 MHz, don't rectify in the first place.
If you want the ~14 MHz, use a bandpass filter rather than a lowpass.
Bob
