@SeanB,
How do components in parallel become out of sync (for lack of correct description)? Would 3 or 4 in parallel offered more protection or just higher probability of failure?
If you keep a constant voltage across a diode, then as it gets hotter, it will conduct very much more current. This behavior is the opposite of most resistors, and it leads to a positive feedbag spiral of "current hogging".
Suppose you have to handle a current of one amp. And let's say you can easily find diodes that are capable of handling 0.5A. So you decide to put three of them in parallel, so that each one will handle 0.33A, giving you a nice margin of safety, right?
Problem is, the diodes won't be perfectly matched, or even if they're perfectly matched at the factory, they won't be exactly at the same temperature in your device. Suppose one gets a tiny bit warm and starts conducting 0.35A, while the others are handling 0.325A each. The one carrying more current will get relatively warmer (because of the energy dissipated by the higher current), and carry more current, while the ones carrying less current will get relatively cooler, and conduct less. Soon one is carrying 0.4A, while the others are carrying 0.3A. This is a positive feedback spiral, and it won't be long before the one that's conducting more warms up still further, conducts more, and eventually exceeds its 0.5A rating.
It will soon fail open circuit and cause the full 1.0A to be shared among the remaining two diodes. One of those two will warm up more than the other, hog the current, and fail.
Google "current hogging" for more explanation and examples.
The only good solution is to insert some means distributing the current among the various diodes, so that if one starts conducting a bit better, it won't be allowed to hog all the current. Or to use one big diode instead of lots of little ones in parallel.
