I’m not sure what value resister I have. I’ve done numerous google searches with no clear answer. It’s a cement wire wound resistor. The marking are K S C 2.7?K 5W It’s from the 70’s. I think it’s a 2.7K ohm 5 watt but with the ohm symbol between the 2.7 and the K I’m not sure. I am converting a PC ATX power supply for use as a bench PS and need a dummy load on the 12V line to stabilize when using small amounts of current. I think this resister is to much for that use. 27ohm 5w was suggested and I’m to impatient to order one so I’m scrounging through a pile of old parts.
Any suggestions on what other values may also work?
thanks
