So I acquired a large a mount of components from a lab that closed it's doors. Some of these are already sorted, some are not - however all have just the part number on the box, and they are not sorted by type but number (so you have optocouplers right in between opamps and 555 timers).
I was wondering how I can keep track of parts without having to go full-on make a spreadsheet of what I have. With resistors and capacitors it is generally quite easy - just put the same size in boxes (10 ? 1/2 W or 12uF 100V electrolytic). But for ICs/silicon in general, it's more challenging. For example, I imagine that at some point I might need an opamp for a project (perhaps a repair). Apart from knowing specs out of heart, it can be hard to know what part is most suited, without having to look up datasheets of each, which would be a lot of work. Do you have any suggestions as to how to store these parts? Excel spreadsheet with some numbers I have and their core specs? (with opamps, this would be RIRO/RTR/neither, GBW, low-frequency gain, UGFB stable)? Have these printed on the little boxes?
