Hello.
I know that ppm is parts per million, but I am choosing between using two parallel 2mΩ resistors each rated with 200ppm/°C, 0,5% tolerance, 2W or one single 1mΩ resistor that's rated with 30ppm/°C, 0,5% tolerance, 3W but the single 1mΩ resistor costs twice as much as the two 2mΩ resistors but I don't know how to evaluate the ppm/°C value for both of these options.
First of all, what does the two parallel 200ppm/°C resistors amount to in terms of ppm/°C?
I know that two parallel 0,5% tolerance resistors is probably more accurate than a single 0,5% tolerance resistor, but I can't explain to my self why that is, so I don't know if ppm/°C could be treated in the same way.
Is the answer to the above that since each resistors value are decreased, each 2mΩ resistor amounts to 0,5mΩ(total amount of 1mΩ, there are two resistors hence 0,5mΩ), so could it be said that the tolerance is 0,5% out of 0,5mΩ which will be smaller than 0,5% out of 1mΩ?
How and why does the two parallel 0,5mΩ(2mΩ) resistors each with 0,5% tolerance combine into the final tolerance value, is the value of the combination still 0,5%?
I know that the 2Ω resistors aren't 0,5Ω but are still 2mΩ, or are they?, I guess I am trying to think of this in a way to develop a more intuitive feel for the results.
As for ppm/°C, so each °C brings about a change in resistance of x ppm, can I simply divide the resistor value by 1 000 000 and multiply the resulting value with in these cases 200 and 30?
I feel as I should have done more google searching but I have pretty severe ADD and I have simply not manage to get that task done while I have been able to open this thread.
Regards
