I am trying to be careful, but SWMBO is working me. I might want to be a bit wary, she is the sole beneficiary of the insurances policies!!
Sounds like it's time for a hard hat, insulated steel toe boots, insulated gloves, and decent safety goggles. Perhaps even a bullet proof vest.
I envy those that have the space - an 8ft bench with surrounding storage is a luxury I simply don't have. I set aside a 4ft bench for electronics within my workshop (garage) which also contains mostly machine tools.
I'm with
cdev; that's excellent use of what you have available.
I'm almost done with mine so its not quite ready for the show your bench thread. I built the bottom months ago by gluing laminate to plywood then routering out small sections to keep the stuff from sliding around then recently decided to make it the same dimensions as my reloading stand to make it sit on top.
Looks good so far.
BTW, does the work surface slide out so you can use a chair?
I ask, as it looks like there may be some sort of drawer slide mech. between it and the lower cabinet portion.
